$desc['phbanner']['alt']}
ESA Series
Three Phase I 5-30kW/5-108kWh
The GoodWe ESA Series is an all-in-one energy storage system that integrates inverter, battery, and energy management—delivering efficient, flexible, and reliable power for homes and small businesses.
More Features to Explore
    -20℃ to+55℃ Reliable Operation
    AFCI 3.0
    <4ms Backup Switching
Power in Silence. Life in Balance.
    1st Layer:
    Starting at the source.
    Custom Low-noise fan
    2nd Layer:
    Smart temperature control.
    Real-time adaptation
    3rd Layer:
    Silence in your hands.
    Industry’s first ultra silent mode
*5~8kW I Operating noise as low as 30dB at 25°C ambient.(WHO guidelines: indoor noise levels ≤30 dB(A) at night support undisturbed sleep.)
Smarter AI. Knows You Better.
Up to 30% reduction in electricity bills
Your 24/7 Smart Energy Expert.
AI predicts tomorrow's solar output and your home's power needs using weather and electricity price data — so your system knows in advance when to store, use, or sell energy.
Based on the forecast, AI automatically schedules charging, discharging, and home usage at the best times — everything is clearly shown in one simple dashboard.
By combining accurate forecasting and smart scheduling, AI Mode helps you avoid peak prices and maximize solar usage — saving up to 30% on your bills compared with traditional TOU mode.
GoodWe AI Agent
Energy Forecast
Smart Schedule
AI Mode Cost Saving
Power You Can Trust
6-layer Protection
    Cell-level Protection
    Electrical Protection
    Structural Protection
    Monitoring-level Protection
    System-level Protection
    Emergency Protection
Built for Fire Safety
Safety is engineered into the system from the battery cell to the internal protection design. With multiple fire-safety mechanisms working together, it helps reduce risks and keeps energy storage safe and reliable.
  • Top-brand LiFePO4 battery cell
  • Pressure relieve valve
  • Thermal-electric separation
  • Aerosol-based fire extinguishing
Built with Installers in Mind
10 mins. Plug. Power. Go.
Designed for fast installation. Battery modules stack easily with a plug-and-play structure. Quick-connect terminals on the grid and backup sides eliminate complex wiring, while the clip-on CT requires no cable cutting. With no external STS needed, installation is simpler and faster—completed in about 10 minutes.
1-click commissioning
1 APP controls all
More Options. More Flexibility.
Easily expand or upgrade your system. Mix batteries of different capacities, old or new.
    Adapts to Harsh Environments
    From blowing sand to freezing snow, the system is built to keep powering your home. With IP66 protection against dust and water, and reliable operation down to -20°C*, it delivers dependable energy even in the toughest conditions.
    IP66 Protection
    -20°C Reliable Operation
    *-20°C operation available only with optional heating module.
    Faster Response , Lower Cost
    Up to 1C Cell
    With 1C battery technology, you get the same power output with fewer batteries — reducing upfront costs and system size. Fast charge and discharge ensure quick response to sudden power demands, keeping your home powered smoothly and reliably.
    Reduced Initial Investment
    Shortened Payback Period
    More Solar, More Power
    Capture more solar.
    Charge and power simultaneously.
    Maximize energy all day.
    With 200% PV oversizing support, a 10 kW inverter can connect up to 20 kW of solar panels — giving you double the solar input without upgrading your system, while enabling simultaneous battery charging and home power supply.
    Your Home, Always On
    Power on. Life uninterrupted. Peace of mind.
    Up to 80A Bypass Current
    Whole-home Backup
    The GoodWe ESA series features an internal 80A bypass, supporting whole-home backup to keep your entire house powered during outages.
GW5K-ETA-G20
700 ~ 950
6.7 / 7.4
21 / 21 / 21
Max. Apparent Power to Grid (kVA)
5
5
GW6K-ETA-G20
700 ~ 950
8.1 / 8.9
21 / 21 / 21
6
6
GW8K-ETA-G20
700 ~ 950
10.7 / 11.8
21 / 21 / 21
8
8
GW10K-ETA-G20
700 ~ 950
13.4 / 14.7
21 / 21 / 21 / 21
10
10
GW12K-ETA-G20
700 ~ 950
16.1 / 17.7
21 / 21 / 21 / 21
12
12
GW15K-ETA-G20
700 ~ 950
20.1 / 22.1
21 / 21 / 21 / 21
15
15
GW20K-ETA-G20
700 ~ 950
26.7 / 29.4
21 / 21 / 21 / 21
20
20
GW25K-ETA-G20
700 ~ 950
33.3 / 36.7
21 / 21 / 42 / 42
25
25
GW29.999K-ETA-G20
700 ~ 950
40.0 / 44.1
21 / 21 / 42 / 42
29.999
