2020-04-28
GoodWe is world’s first and only inverter brand compatible with BYD Battery-Box Premium HVM: four storage products now compatible
GoodWe is world’s first and only inverter brand compatible with BYD Battery-Box Premium HVM: four storage products now compatible-News
GoodWe Storage Solution
GoodWe has the most comprehensive storage portfolio in the industry, including European brands, covering single-phase, three-phase, high voltage and low voltage. GoodWe invests a lot on researching and developing storage solutions in different application scenarios and has massive potential in the storage sector. In markets where electricity prices are high such as Italy, an increasing number of residents prefer to install hybrid inverters due to FIT and high electricity bills, with the intention to maximize self-consumption. GoodWe’s backup function ensures steady 24-hour power supply in extreme weather conditions. While in countries where grids are unreliable or in poor condition, the Hybrid systems are the best alternative for self-sufficiency. The market is hungry for storage and GoodWe has the ingredients.
Name of Inverter: GoodWe ET Series, Three-phase Energy Storage Inverter, Dual-MPPT
Unique Selling Points:
  • Maximum efficiency up to 98.2%
  • Uninterruptible Power Supply
  • Wide battery voltage range
  • Fanless design, quiet operation
    Name of Inverter: GoodWe EH Series, Single-phase Energy Storage Inverter, Dual-MPPT
    • UPS automatic switch in 10ms
    • Wide battery voltage range 85~450V
    • Large loads when back-up
    • Maximize self-consumption
    • Pre-wired, plug & play
    Name of Inverter: GoodWe BT Series, Three Phase AC-Coupled Retrofit Inverter, 5-10kW
    • UPS function (uninterruptible power supply)
    • High voltage battery (180-600V)
    • 10% AC output overloading
    • Battery input reverse polarity protection
    Name of Inverter: GoodWe BH Series, AC-Coupled Retrofit Inverter, 3-6kW
