BAT-C Series
C&I Battery System I 60/112.6kWh
BAT-C Series-BAT-C Series
IP55
LiFePO4
Battery system for outdoor C&I energy storage applications
Paired with GoodWe ET hybrid inverters and the Static Transfer Switch (STS) box, BAT-C high-voltage lithium battery system is available in 61.4 kWh and 112.6kWh capacity and offers a scalable, compact, and easy-to-install storage solution for C&I applications. This powerful combination enables efficient energy backup, peak shaving, and optimized load management. BAT-C offers industry leading safety features such as aeroso based fire suppression at both module and battery level, LFP technology with high cycle stability and long cycle life. With effective temperature management to enable outdoor operation across different climate zones, this all-in-one energy storage solution is a great fit for medium and large C&I scenarios, including industrial parks, agricultural and commercial complexes. Additionally, BAT-C supports parallel connections of up to 4 clusters, enabling flexible configurations and expansion to 450.4 kWh to meet growing energy storage demands.
Advanced 6-Layer safety protection
Support Continuous 0.9C charging & 1.1C discharging
Support 4 units in parallel up to 450kWh
Aerosol-based fire suppression system at pack- and cabinet-level
IP55
LiFePO4
Highest safety standards and reliability
BAT-C battery offers industry leading safety features such as aeroso based fire suppression at both module and battery level, providing fast-acting protection and delivering multi-layered safety across the entire system. The battery is built on reliable LFP technology, offering high cycle stability for long-lasting performance. Safety is enhanced through pack-level humidity monitoring with automatic dehumidification, ensuring optimal internal conditions.
Pack-level humidity monitoring and automatic dehumidification
Expandable C&I battery system
Designed for dynamic energy needs, the BAT-C battery supports continuous charging at up to 0.9C and discharging at 1.1C, enabling fast energy response. With support for up to 4 units in parallel, the system scales effortlessly to 450kWh to meet growing energy storage demands for a wide range of commercial and industrial applications, such as industrial parks, agricultural and commercial complexe etc.
Flexible and scalable C&I applications
Intelligent storage solution for mediun to large C&I applications
BAT-C battery system can be paired with a hybrid inverter from the GoodWe ET series and the Static Transfer Switch (STS) box to create a compact storage solution for medium to large C&I applications. Available features include energy back-up, peak-shaving and load management. The hybrid inverter can be purchased separatly and can be attached to the side of the battery system.
Energy back-up
Peak-shaving
Load management
GW61.4-BAT-AC-G10
Usable Energy (kWh)
60
Nominal Voltage (V)
307.2
Max. Charge / Disharge Current (A)
180 / 220
Fire Safety Equipment
Aerosol (Pack & Cabinet Level)
Ingress Protection Rating
IP55
GW112.6-BAT-AC-G10
Usable Energy (kWh)
110
Nominal Voltage (V)
563.2
180 / 220
IP55
