Fanless & quiet
Elegant & compact
Easy retrofit for optimised energy autonomy
Increasingly, owners of PV systems are looking to expand into energy storage solutions, thereby enabling energy back-up and enhanced independence. Ideal for solar power system upgrades and retrofit projects, the BT battery inverter is installed on the AC-side of the on-grid inverter and can be combined with a range of battery capacities, including GoodWe high-voltage battery series Lynx Home F.
UPS level switching < 10ms
Smart home integration
IP66 ingress protection
Compensates asymmetry Charging/Discharging
Fanless & quiet
Elegant & compact
High backup output power with overload capability. Wide battery voltage range (180-600V) supports various battery capacities and power.
Integrated dynamic power export limit
Elegant and compact design, with a high output without taking up much space. All connections are available on the bottom side of the inverter, making the installation and maintenance easier.
Fanless cooling
Easy to handle
GW6K-BT
180~600
Max. Charging / Discharging Current(A)
25/25
400/380, 3L/N/PE
6600
6000
GW8K-BT
180~600
25/25
400/380, 3L/N/PE
8800
8000
GW5K-BT
180~600
25/25
400/380, 3L/N/PE
5500
GW10K-BT
180~600
25/25
400/380, 3L/N/PE
11000
10000
