DNS G3 Series
String Inverter I 3 - 6 kW | 2 MPPTs | Single Phase
16A / string
2 MPPTs
Smart and quiet operation with maximised energy yield
The DNS G3 inverter incorporates functionalities to optimise energy yield while running safely, reliably and quietly. Enabling current input up to 16A, it is compatible with high-power PV modules. With its modern design and smart home readiness, the DNS G3 offers a flexible solution for homeowners seeking to future-proof their energy system. Additional functionalities, including power export limiting and load monitoring, can be provided with GoodWe HomeKit 1000 or GM1000.
Smart energy management
IP66 rating
Optional AFCI function
Optional SPD type II (DC side)
Up to 16A per string
Low start-up voltage
16A / string
2 MPPTs
Smart and efficient operation
With the DNS G3 inverter, homeowners profit from valuable features like smart home readiness as well as a stylish design. The inverter is compatible with SG-ready heatpumps for integration in Smart Home systems. Additional functionalities, including power export limiting and load monitoring, can be provided with GoodWe HomeKit1000 or GM1000. Natural convection is the main cooling method, thereby facilitating silent operation.
Silent operation
LCD screen
Highest safety standards
With optional Arc Fault Circuit Interrupter (AFCI), the inverter is able to detect arc fault failure, sending alarms through monitoring systems and shutting down the inverter operation simultaneously. Optional Type II Surge Protection Device (SPD) on the DC side protects the system from lightning hazards.
IP66 rating
Maximised energy output
The DNS G3 inverters can generate up to 10% additional power compared to the nominal output, increasing the overall yield. Low start up voltage enables power generation from early morning to late evening. With 16A maximum current input per string, the inverter series is compatible with high-power modules. The DNS G3 comes with two MPPTs, thereby enabling improved system design flexibility and energy harvest levels.
Increased yield ( 110% AC power )
Low
16A
GW6000-DNS-30
Max. Input Voltage (V)
Weight (kg)
13.4
220/230/240
GW5000-DNS-30
Weight (kg)
12.8
220/230/240
GW4200-DNS-30
Weight (kg)
12.8
220/230/240
GW3600-DNS-30
Weight (kg)
12.8
220/230/240
GW3000-DNS-30
Weight (kg)
12.8
220/230/240
