ESA Series
Residential Energy Storage System I 3-10 kW / 5-108 kWh
ESA Series- ESA Series
IP66
All-in-one
Smart and scalable residential all-in-one energy storage solution
The GoodWe ESA Series is an all-in-one residential energy storage solution (ESS) that combines reliability and advanced functionality. It integrates the inverter, battery, UPS-grade switching, and battery enclosure in a pre-wired modular system—streamlining installation and reducing costs.
Compact, elegantly designed, and IP66-rated for durability, the unit operates reliably indoors or outdoors in any weather conditions. With smart controls, scalable storage, and flexible configurations, the ESA empowers homeowners to manage their energy needs with  confidence and ease.
The innovative modular and stackable design ensures adaptability, growing alongside your household energy demands and making true energy independence simpler than ever.
AI-driven EMS and <4 ms UPS-level switching
Different capacities old or new batteries mixing
Supports 6 batteries per stack, scalable up to 54kWh
IP66
All-in-one
Scalable Residential Applications and Optimized Performance
Designed with versatility in mind, this smart all-in-one ESS adapts seamlessly to your household's energy needs. Its modular and stackable architecture supports easy expansion, allowing you to increase battery capacity and enhance system performance over time, growing alongside your home's energy demands. With 1C charge/discharge, 20A per string and 200% PV oversizing your household will benefits from more solar energy and incresed independance from the grid.
Allows different capacities of old and new batteries mixing
Fully expandable for future energy storage upgrades
Compact, Elegant, and User-Friendly Design
The GoodWe ESA Series is a compact, all-in-one Energy Storage System (ESS) is engineered for superior safety and performance. Featuring advanced 5-layer safety protection, it delivers comprehensive safety across every operational stage. Integrated cell- & module-level monitoring maintain optimal internal conditions, ensuring long-term reliability and performance. Additionally, the ESA Series is equipped with an aerosol fire extinguishing system at module levels for enhanced protection.
All-in-one modular design for simplified integration
Pre-wired components for faster, hassle-free installation
Modern design for seamless integration into your home
Highest safety standards and reliability
Advanced 5-Layer safety protection
Cell-level & module-level monitoring
GW10K-EHA-G20
350 ~ 550
35.6 / 29
20
Max. Apparent Power to Grid (VA)
10000
10000
GW8K-EHA-G20
350 ~ 550
31.6 / 23.2
20
8000
8000
GW6K-EHA-G20
350 ~ 550
23.7 / 17.4
20
6000
6000
GW5K-EHA-G20
350 ~ 550
19.8 / 14.5
20
GW3.6K-EHA-G20
350 ~ 550
14.3 / 10.5
20
3600
3600
GW3K-EHA-G20
350 ~ 550
11.9 / 8.7
20
3000
3000
