IP65
Optimized performance on PV-module level
GoodWe’s micro-storage is a compact, all-in-one energy solution that makes clean power simple and accessible. Designed to lower electricity costs and support off-grid needs, it combines a built-in inverter and battery in one intelligent system. A breathing light intuitively indicates operating status, while the stackable design allows effortless capacity expansion as your energy needs grow. With its seamless integration, elegant design, and smart functionality, GoodWe’s micro-storage empowers you to take control of your energy independence.
Plug-and-play design, easy and simple installation
Modern aesthetics
Heating technology for reliable performance @-20°C
Stackable to 9.6kWh – supports mixing old and new batteries
IP65
Designed with versatility in mind, this micro-storage adapts seamlessly to your household’s energy needs. Its modular and stackable architecture supports easy expansion, allowing you to increase battery capacity and enhance system performance over time. As your energy demands grow, it evolves with you — helping your household achieve greater independence from the grid.
Supports 4 batteries per stack, scalable up to 9.6kWh
Allows different capacities of old and new batteries mixing
The GoodWe micro-storage offers a compact solution that surpasses traditional split storage systems by simplifying installation and reducing costs. Its modern design delivers outstanding performance while enhancing your home’s aesthetics — combining reliable technology with refined style.
Modular design for simplified integration
GW0.8/1.9-ESA-PS-G10
Max. Input Voltage (V)
60
18
4 / 1
Weight (kg)
26
220 / 230 / 240, L / N / PE
