Hybrid Inverter I 50/100 kW I 1-2 MPPT I Three-phase I HV
Peak-shaving
Back-up
Reduced energy cost and uninterrupted power supply for C&I applications
Commercial and industry (C&I) energy storage solutions can effectively encounter rising energy cost, maintain stable operations, and secure competitiveness. In addition to increased self-consumption, the GoodWe energy storage systems allow users to level out peak demands and avoid additional grid fees. The powerful backup delivers additional value to organisations with a strong reliance on uninterrupted power. The ETC/BTC inverters are designed to be connected exclusively to the GoodWe battery system Lynx C and can be paired with up to three Lynx C batteries per battery input, thereby providing a wide range of battery capacity options for enhanced flexibility.
Peak shaving functionality
Powerful back-up
UPS level switching < 10ms
100% unbalanced power output
Compatible with GoodWe Lynx C battery
Flexible String design (12.5A - 20A)
Peak-shaving
Back-up
With the ability to switch to backup mode in less than 10 ms, an uninterruptible power supply is always operational for critical loads.
Black start capability
The lightning protection on both AC and DC sides prevents voltage peaks from destroying connected devices and secures system reliability.
Built-in Type II SPD (Type I + II offered as optional configuration)
Combined with GoodWe battery system Lynx C (101kWh - 156kWh), the ETC / BTC hybrid inverters enable a high degree of self-consumption. Backed by powerful backup capabilities, unbalanced power output and peak-shaving, the C&I storage system facilitates lower cost while ensuring uninterrupted power.
468
Lynx C battery compatible 101 - 468 kWh
100%
Unbalanced power output
GW100K07-ETC
200~865
100/100
100
110000
Max. Output Apparent Power (Back-up) (VA)
110000
GW50K07-ETC
200~865
100/100
100
55000
55000
