ETR Series
80-125kW I Three Phase Hybrid Inverter (HV)
ETR Series ETR Series 80-125kW
IP66
60dB
Designed for evolving Commercial and Industrial (C&I) energy needs, the GoodWe ETR battery ready inverter combines PV generation and future-ready energy storage in one flexible platform. Its Battery-Ready design allows businesses to start with solar today and seamlessly add storage whenever needed, reducing upfront investment while simplifying future expansion. Compatible with the GoodWe BAT-C 261kWh battery system, ETR supports intelligent energy management for applications such as self-consumption, peak shaving, backup power, and microgrid support. With reliable on/off-grid switching and scalable architecture, ETR delivers a flexible and dependable solution for modern C&I energy systems.
Battery-Ready for Future Storage
High-Efficiency PV Performance
Seamless Backup Power
Industrial-Grade Reliability
IP66
60dB
Reliable Power Backbone for Modern C&I Energy
ETR is designed to provide a stable and efficient energy foundation for commercial and industrial users, combining solar generation and future storage capability in one integrated platform.
IP66 industrial protection
Up to 99.9% MPPT efficiency
Scalable storage expansion
Flexible Energy Transition from PV to Storage
Enables a smooth transition from solar-only operation to full energy storage systems, helping businesses optimize investment timing and long-term energy planning.
Battery-ready upgrade without replacement
<10ms seamless switching
Wide temperature operation (-35°C to +60°C)
GW125K-ETR-G10
700 ~ 1000
180.0
Max. MPPT Current (A)
42
Max. AC Apparent Power (kVA)
137.5
125.0
GW124.99K-ETR-G10
700 ~ 1000
178.5
42
124.99
124.99
GW110K-ETR-G10
700 ~ 1000
172.8
42
121.0
110.0
GW100K-ETR-G10
700 ~ 1000
157.1
42
110.0
100.0
GW99.99K-ETR-G10
700 ~ 1000
142.8
42
99.99
99.99
GW80K-ETR-G10
700 ~ 1000
125.7
42
88.0
80.0
