GT Series
String Inverter | 100 - 125 kW | 8/10 MPPTs | Three Phase
Smart & low-noise fans
Robust design
Increased ROI for C&I solar power projects
Characterized by its high power density, the GT Series string inverter provides high energy yields for commercial and industrial PV applications. Multiple MPPTs and high input current of 21A per DC string increase the overall yield with high-power PV modules. Type II surge protection provides safety and reliability for the PV system from lightning.
High power density
Up to 21A per string
Full power up to 45°C
Robust design
Lower CAPEX and OPEX
High power density with up to 137kW maximum power for low voltage grid applications (400V).
High power density
150% DC input oversizing
Maximised energy output
10% additional power up to 45 °C ambient temperature provides maximal generation. Up to 12 MPPTs and high input current of 21A per DC string increasing the overall yield with high power PV modules.
Superb Safety & Reliability
Equipped with IP66 and optional C5 corrosion protection, GT Series endures harsh environments for stable performance throughout its life cycle. Both the DC side and AC side are equipped with Type II surge protection to protect the inverter from lightning, providing upgraded safety and reliability for the PV system.
Type II Surge Protection & optional AFCI
GW125K-GT
Max. Input Voltage (V)
42
10 / 2
Max. Efficiency
99.0%
220 / 380, 230 / 400, 277 / 480, 3L / N / PE or 3L / PE
GW110K-GT
42
10 / 2
Max. Efficiency
98.8%
GW100K-GT
42
8 / 2
Max. Efficiency
98.8%
