Lynx U G3 Series
Low voltage battery I 5 kWh
Up to 30 Batteries in parallel
Safe and flexible LV battery system for PV power self-consumption and back-up
Featuring high-performance LFP battery technology for enhanced safety and reliable performance, GoodWe’s low-voltage (LV) Lynx U G3 Series has been specially designed for residential applications. The system can reach a maximum 90A charging/100A discharging rate providing smart and efficient operation. The battery's versatile installation options—floor or wall mounting—make it easy to set up, while its expandability allows for connection of up to 30 modules in parallel, reaching a total capacity of 150 kWh. Equipped with optional functions such as battery heating technology and fire protection, it operates efficiently even at low temperatures and it can achieve the highest safety standards.
Remote diagnosis and update via inverter
Fire protective LFP battery system
IP65 protection for outdoor installation safety
Maximised power back-up
Wide capacity range, scalable from 5 - 150 kWh when connecting up to 30 modules in parallel. Compatible with GoodWe's low voltage hybrid and battery inverters.
Flexible and scalable capacity
High battery cycle stability
High energy density
Highest safety standards
Lithium iron phosphate (LFP) batteries are reliable and safe to use due to high chemical and thermal stability. Going beyong typical safety standards, the system is compliant to the advanced battery safety standard VDE 2510-50.
Reliable LFP battery cell
IP65 for both indoor and outdoor installation
Fire protection
Flexible and Scalable Applications
Lynx U G3 Series boasts a modular design for parallel connection of up to 30 batetry modules, providing enhanced flexibility in energy storage solutions. This series also supports applications of storage systems in extreme low temperatures through the optional battery heating technology.
Modular design for parallel connection
Compatible with GoodWe residential storage inverters
Low temperature readiness
LXU 5.0-30
Usable Energy (kWh)
5
Nominal Voltage (V)
5.12
60 / 100
Installation Location
Wall Mounted / Grounded
Enclosure Type
IP65
