<30dB
20A
Flexible design options for maximised energy yield
The fourth generation of GoodWe’s MS single-phase inverter is the optimal solution for residential PV rooftops with complex layouts. It features three MPPTs, allowing more flexible PV string design and higher energy harvest. With 200% PV oversizing, 20A input per string, and a low start-up voltage, the MS G4 maximizes generation even under weak sunlight conditions. The MS G4 supports mixed parallel installation with DNS G4 using the EzLink3000 smart dongle—offering scalable, modular, and cost-effective system expansion. Optional AI-driven AFCI 3.0, Rapid Shutdown 2.0 with built-in transmitter, and Type II SPD on both AC & DC sides ensure maximum protection and compliance with global safety standards. Compact, quiet (<30dB), and cyber-secure, the MS G4 is designed to meet both today’s and tomorrow’s residential energy demands.
200% PV oversizing & 20A per string
Optional AI-driven AFCI 3.0 & standard SPD Type II (AC & DC)
Quiet operation <30dB & compact design (16% lighter than G3)
Parallel-ready with DNS G4 via EzLink3000
<30dB
20A
The MS G4 series is tailor-made for complex rooftops and growing system needs. With three MPPTs, flexible PV design is easier than ever. Through the EzLink3000 smart dongle, MS G4 can be paralleled with DNS G4 in up to 10-unit systems without requiring a datalogger. This setup makes phased installations and future expansions simple, cost-effective, and design-friendly.
PV system expansion with mixed DNS G4 & MS G4 paralleling
Easy paralleling via GoodWe's EzLink3000 smart dongle
With 200% PV oversizing, 20A per string, and low start-up voltage, MS G4 captures more energy throughout the day—even under weak sun. Its compatibility with the latest high-power PV modules and flexible 3 MPPT architecture ensures optimal generation on rooftops with multiple orientations or partial shading.
200% PV oversizing & 20A max per string
3 MPPTs
MS G4 integrates top-tier safety technologies including AI-driven AFCI 3.0 (optional) for proactive arc detection and shutdown, Rapid Shutdown 2.0 with built-in transmitter for emergency response safety, and Type II SPD on both AC and DC sides to protect against lightning and surges. The inverter is also built with cybersecurity for secure remote access and monitoring.
Optional AFCI 3.0 & SPD II on both AC and DC sides
Cybersecurity built-in
GW7.5K-MS-G40
Max. Input Voltage (V)
20
3/1
Weight (kg)
220 / 230 / 240, L / N / PE
GW8.5K-MS-G40
20
3/1
Weight (kg)
GW10K-MS-G40
20
3/1
Weight (kg)
