SBP Series
Retrofit Battery Inverter I 3.6-5 kW | Single phase | LV
Fanless & Quiet
Elegant & Compact
The GoodWe SBP series is the world’s first AC-coupled battery storage retrofit solution with UPS function. It can effectively upgrade any existing string inverter system by adding a backup battery. Capable of being grid-interactive, it allows users to store surplus power and sell it back to the grid when demand peaks and the price of electricity is at its highest. With a UPS-level switching function (switching time <10 ms), the GoodWe SBP provides an uninterruptible power supply to critical loads. It runs reliably under even the most extreme conditions with metal aluminium housing with IP65 protection.
<10 ms UPS-level switching
IP65 ingress protection
Quality and robust components
Fanless & Quiet
Elegant & Compact
Optimised Energy Autonomy
Up to 50A charge and discharge current ensures high charge and discharge power of batteries up to 2.3kW. Compatible with GoodWe batteries and multiple other brands.
High charge and discharge power
Integrated dynamic power export limit
GoodWe SBP is suitable for both single-phase & three-phase systems, adapting to various architecture conditions of users. Designed to interact with the grid, SBP allows selling electricity back to the grid or charging batteries through the grid to fit the different scenarios.
Grid-interactive
Suitable for both single-phase & three-phase systems
GW5000S-BP
40~60
Max. Charging Current(A)
100/100
Max. Discharging Current (A)
230
Protection Degree
GW3600S-BP
40~60
75/75
230
3680
Protection Degree
3680
