Through these cookies we collect information about your visit on our website. Respect for your privacy is central to our policy. Detailed information about our privacy and cookie policy can be found in the enclosed sections. In order to proceed now, we ask your permission that you agree with our conditions. Thanks in advance for your cooperation Privacy and Cookie policy.
String Inverter | 8 - 20 kW | 2 MPPTs | Three Phase
Fanless & quiet
Elegant & compact
Maximised energy yield for high-power PV rooftops
A perfect fit for three-phase residential and small commercial systems with high-power PV modules, the SDT G2 PLUS+ inverters allow for high current input up to 16A. The smaller inverters are designed for silent operation, while optional Type II surge protection on both AC and DC sides enhances overall safety. Smart energy management - including 24-hour load consumption monitoring - can be facilitated by adding the GoodWe HomeKit 3000.
Dynamic power export limit
Monitoring of the load consumption possible
Optional Arc Fault Circuit Interrupter (AFCI)
Optional surge protection SPD type II
Fanless & quiet
Elegant & compact
With optional Arc Fault Circuit Interrupter (AFCI), the inverter is able to detect arc fault failure, sending alarms through monitoring systems and breaking the circuit simultaneously. Optional Type II Surge Protection Device (SPD) on both sides protects the system from lightning hazards in extreme environments.
Optional AFCI
Smart energy management - including 24-hour load consumption monitoring - can be facilitated by adding the GoodWe HomeKit 3000. Natural convection is the main cooling method for the smaller inverters, thereby facilitating silent operation.
Compatible with GoodWe HomeKit 3000
Smart energy readiness
Silent operation
The SDT G2 PLUS+ Series can generate 10% additional power compared to the nominal output, increasing the overall yield. The high input current maximizes the generation thanks to its compatibility with high-power PV modules. The low startup voltage extends the generation time from early morning to late evening.
Increased Yield ( 110% AC power )
16 A
Up to 16 A max. DC Input Current Per String
GW20K-SDT-20
Max. Input Voltage (V)
2/2
Weight (kg) :
26.0
380/400/415, 3L/N/PE
GW17K-SDT-20
2/2
Weight (kg) :
26.0
GW15K-SDT-20
2/2
Weight (kg) :
26.0
GW12KLV-SDT-20
800
2/2
Weight (kg) :
26.0
220/127, 3L/N/PE
GW12K-SDT-20
2/2
Weight (kg) :
23.5
GW10K-SDT-20
15
Weight (kg) :
20.5
GW8000-SDT-20
15
Weight (kg) :
20.5
GW6000-SDT-20
1000
Weight (kg) :
15.0
400, 3L/N/PE
GW5000-SDT-20
1000
Weight (kg) :
15.0
400, 3L/N/PE
GW4000-SDT-20
1000
Weight (kg) :
15.0
400, 3L/N/PE
