Light & compact
IP66 rating
Maximised energy yield for high-power PV rooftops
A perfect fit for three-phase residential and small commercial systems with high-power PV modules, the SDT G3 inverters allow for high current input. The inverters are designed for silent operation, while the optional Type II surge protection on both AC and DC sides enhances overall safety. Smart energy management including load control and 24-hour load consumption monitoring can be facilitated by adding GoodWe accessories.
Increased yield (both on AC and DC)
Highest safety standards
Silent operation
Light & compact
IP66 rating
The SDT G3 inverter can generate up to 10% additional power compared to the nominal output with higher efficiency, increasing the overall yield. Low start up voltage enables power generation from early morning to late evening. With up to 22A maximum current input per string, the inverter series is compatible with high-power modules. The SDT G3 comes with two MPPTs enabling improved system design flexibility and energy harvest levels.
Increased yield ( 110% AC power )
Up to 22 A max. DC input current per string
Low start-up voltage
With Arc Fault Circuit Interrupter (AFCI), the inverter is able to detect arc fault failure, sending alarms through monitoring systems and shutting down the inverter operation simultaneously. Type II Surge Protection Device (SPD) on both AC and DC sides protects the system from lightning hazards, enhancing overall safety.
Optional AFCI function
Optional surge protection SPD type II
IP66 rating
With SDT G3 inverter, homewoners profit from valuable features like energy management as well as a modern and compact design. The inverter is compatible with smart grid-ready devices for integration in Smart Home systems. Additional functionalities such as 24-hour load monitoring can be facilitated when paired with GoodWe's smart meter. Natural convection is the main cooling method, thereby facilitating silent operation.
Modern and compact design
Silent operation
GW20K-SDT-30
Max. Input Voltage (V)
32/22
2/2-1
Weight (kg)
17.1
220/380, 230/400, 240/415, 3L/N/PE or 3L/PE
GW17K-SDT-30
32/22
2/2-1
Weight (kg)
17.1
GW15K-SDT-30
22
Weight (kg)
16.2
GW12K-SDT-30
22
Weight (kg)
16.2
GW10K-SDT-EU30
22
Weight (kg)
14.7
GW8000-SDT-30
22
Weight (kg)
14.7
GW6000- SDT-30
22
Weight (kg)
14.7
GW5000- SDT-30
22
Weight (kg)
14.7
GW4000- SDT-30
22
Weight (kg)
14.7
