Three-phase HomeKit
HomeKit 3000
24/7 monitoring
Export control
GoodWe HK3000 is a solution designed to monitor load energy consumption in real time, 24 hours a day. Based on best design principles, the HK3000 is tailored to homeowners’ needs and only requires an internet connection. It consists of a smart meter and a Wi-Fi / LAN communication module. An additional advantage of GoodWe HK3000 is that it can be applied to grid-connected systems with Goodwe inverters or even systems without PV and it is a key component in keeping load consumption records. With 60-second update frequency, data is transmitted and stored on the cloud. End users benefit from a better understanding of their electricity consumption and the source from which it is generated. Moreover, if used together with a GoodWe inverter, HK3000 can limit the power exported to the grid.
24/7 Real-time consumption monitoring
Three CTs design – super accurate measurement
Export power control
Cloud data transmission
24/7 monitoring
Export control
Three CTs Design – Super Accurate Measurement
GoodWe HomeKit (HK3000) is designed to connect with three CTs (Current Transformer), which can measure the inverter side and the grid side at the same time.
HK3000
Application
Voltage
110V~240V
Current Range
0.48~120A/200A
Self-Consumption
<5W
Communication
100M Ethernet/ WiFi
