UT Series
String Inverter | 250-350 kW | 12/15 MPPTs | Three Phase
Full-load at 40ºC
Two strings per MPPT
Reduced LCOE for large PV power plants
An ideal choice for large utility-scale, ground mounted PV plants, the UT inverter was designed to support PV investments, facilitate bankability and increase project lifetime. By maximizing energy yield and ensuring continuous high performance even under extreme environmental conditions, it delivers the best value for money. Combined with the GoodWe Solar Communication Unit SCU3000A, the UT inverter provides reliable remote monitoring and control via High-speed Power Line Communication (HPLC).
Full-load operation at 40ºC
Flexible DC and AC cabling options
Dynamic response time <30ms
Full-load at 40ºC
Ease of installation and maintenance
Compatible with 10mm2 PV and 2x 240 mm2 AC cables
2 strings per MPPT
Up to 600m comms distance with HPLC
Designed to minimise LCOE
Full load operation up to 40°C
All-in-one vertically integrated solution
Smart I-V curve scan
Certified for most grid standards
Open protocol for ecosystem integration
PV-free STATCOM operation
GW250KH-UT-G20
Max. Input Voltage (V)
1500
40
12/2
Max. Efficiency
99.01%
800, 3L/PE
GW320K-UT
1500
15/2
Max. Efficiency
99.01%
800, 3L/PE
GW320KH-UT
1500
40
12/2
Max. Efficiency
99.01%
800, 3L/PE
GW350K-UT
1500
15/2
Max. Efficiency
99.01%
800, 3L/PE
GW350KH-UT
1500
40
12/2
Max. Efficiency
99.01%
800, 3L/PE
