XS G3 Series
String Inverter | 0.7 - 3 kW | 1 MPPT | Single Phase
Silent operation
A4 size
Compact and silent inverter for modern homes
Designed for high energy yields and silent operation, the XS G3 series is an ultra-small solar inverter for residential PV systems. Installed in the house or on an outside wall, it supports multiple smart home integration protocols and is compatible with high-power modules, catering up to 16A. Additional functionalities, including power export limiting and 24h load monitoring, can be provided with GoodWe accessories.
24 h load monitoring
Integrated load control
IP66 rating
Optional AFCI function
Up to 16A
Compact and lightweight
Silent operation
A4 size
Maximised Energy Output
XS G3 inverters can generate up to 10% additional power compared to the nominal output, increasing the overall yield. Low start up voltage enables power generation from early morning to late evening.
Increased yield ( 110% AC power )
Low start-up voltage
Highest safety standards
With optional Arc Fault Circuit Interrupter (AFCI), the inverter is able to detect arc fault failure, sending alarms through monitoring systems and shutting down the inverter operation simultaneously. Optional Type II Surge Protection Device (SPD) on the AC and DC sides protects the system from lightning hazards.
Optional SPD type II
IP66 rating
Smart and efficient operation
With the XS G3 inverter, owners of residential PV systems benefit not only from a sophisticated and elegant inverter, but also from a device that is compatible with SG-ready devices, such as heatpumps, for integration into Smart Home systems. The power export limiting and load monitoring can be easily added with compatible accessories. Natural convection cooling facilitates silent and efficient operation, ideal for residential inverters.
24h
24-hour load monitoring
SG-ready
Smart load control with dry contact
<20dB
Silent operation with natural convection
GW3000-XS-30
Max. Input Voltage (V)
1/1
Weight (kg)
4.6
220 / 230 / 240, L / N / PE
GW2500-XS-30
1/1
Weight (kg)
4.6
GW2000-XS-30
1/1
Weight (kg)
4.6
GW1500-XS-30
1/1
Weight (kg)
4.6
GW1000-XS-30
1/1
Weight (kg)
4.6
GW700-XS-30
1/1
Weight (kg)
4.6
