EH PLUS+ Series
Hybrid Inverter I 3.6 – 6 kW I 2 MPPT I Single Phase I HV
Fanless & quiet
Elegant & compact
Enhanced energy independence for owners of residential PV systems
Efficient solutions for solar power storage are the key to increased levels of energy autonomy. The EH PLUS+ hybrid inverters are designed to maximise energy output, enhance self-consumption, realise peak-shaving and provide a reliable backup power. Featuring a modern design that does not require fans for cooling, the operation is silent and reliable. An on-grid, battery-ready version of the inverter is available. The EH PLUS+ series is compatible with a range of batteries, including the GoodWe Lynx Home F PLUS+.
UPS level switching < 10ms
IP65 ingress protection
High quality components
Fanless & quiet
Elegant & compact
Smart and efficient operations
Integrated dynamic power export limit and load monitoring. Supports multiple communication protocols for smart home integration.
Integrated load monitoring
Highest safety standards
Thanks to the in-built DC type II SPD, EH PLUS+ series can protect DC side from lightning strikes and save the cost of an external device.
Built-in Type II SPD on DC side
Optimised energy autonomy
High backup output power and battery charging power capabilities. Compatible with GoodWe Batteries and a wide range of HV battery brands.
6
High battery charging power 6 kW
10
GW3600N-EH
85~460
25/25
3600/3960
3600
GW5000N-EH
85~460
25/25
5000/5500
GW6000N-EH
85~460
25/25
6000/6600
6000
