Lynx Home F PLUS+ Series
High Voltage Battery I 6.6 - 16.4 kWh
Stackable
VDE 2510-50
Safe and convenient  HV battery system for PV power back-up and energy autonomy
Ideal for smart energy management and back-up optimisation,  high-voltage (HV) battery system Lynx Home F PLUS+ is a perfect match for residential solar systems. The stackable, self-detecting battery modules make the system especially easy to install, while the reliable lithium iron phosphate (LFP) battery cell technology ensures maximum safety. Lynx Home F PLUS+ offers a wide capacity range from 6.6 kWh to 16.4 kWh, is compliant to the advanced battery safety standard VDE 2510-50 and is compatible with GoodWe BH/EH PLUS+/BT/ET inverters.
Remote diagnosis and update via inverter
Reliable LFP battery cell
Up to eight towers in parallel (131kWh)
Stackable
VDE 2510-50
Maximised Power Back-up
Wide capacity range, scalable from 6.6 – 16.4 kWh. Compatible with GoodWe's single and three phase, hybrid and retrofit BH/EH/BT/ET inverters.
Flexible capacity and stackable modules
High battery cycle stability
Highest Safety Standards
Lithium iron phosphate (LFP) batteries are reliable and safe to use due to high chemical and thermal stability. Going beyong typical safety standards for lithium batteries, the system is compliant to the advanced battery safety standard VDE 2510-50.
IP55 for both indoor and outdoor installation
LX F6.6-H
Usable Energy (kWh)
6.55
Nominal Voltage (V)
204.8
25/25
Installation Location
Grounded
Enclosure Type
IP55
LX F9.8-H
Usable Energy (kWh)
9.83
Nominal Voltage (V)
307.2
25/25
Grounded
Enclosure Type
IP55
LX F13.1-H
Usable Energy (kWh)
13.1
Nominal Voltage (V)
409.6
25/25
Grounded
Enclosure Type
IP55
LX F16.4-H
Usable Energy (kWh)
16.38
Nominal Voltage (V)
512
25/25
Grounded
Enclosure Type
IP55
