EHB Series
(South Africa only) Hybrid inverterI 5-10 kW | Single phase | HV
Plug & Play connectors
<10 ms UPS-level switching
AFCI ready & Rapid shutdown
IP65 ingress protection
Convenient Design
Optimised Energy Autonomy
Featuring 4 MPPTs, the EHB 5-10kW Series is the perfect solution to feed solar power to large residential properties, offering you more choices and maximizing total solar generation.  The power supply ability in backup mode supports large loads for critical operations.
4 MPPTs – higher yields
Strong backup power supply
GW5000-EHB
80~495
Max. Charging / Discharging Current(A)
50/50
13/13/13
Max. Continuous Output Apparent Power (VA)
GW6500-EHB
80~495
50/50
13/13/13/13
6500
6500
GW8600-EHB
80~495
50/50
13/13/13/13
8600
8600
GW0010-EHB
80~495
50/50
13/13/13/13
10000
10000
